查看: 2720|回复: 7
26.4 megapixel Canon EOS 5D Mark III by June!
发表于 2011-4-22 21:41:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
We had a tip roll in this weekend regarding the Canon EOS 5D Mark III, which I’d file under the “Perfectly Plausible” category. This person dispels talk of 30+ megapixels that we’ve seen in some rumors for a potential 5D Mark III, stating instead the 5D3 would have a more reasonable 26.4 MP sensor. That said, the specs:
26.4 million effective pixels
ISO expandable to 102,400
19 point AF system, 3 cross-type points
DIGIC 5
4.9 fps continuous shooting
63-zone iFCL metering
1.04 million dot LCD
Improved camera grip
Improved pentaprism, approximately 100% frame coverage
released mid-year
No word on new video codecs or HD output while recording video, but otherwise these are the exact type of specs one would expect in a successor. We’ve seen talk of a 28MP sensor, so the 26.4MP definitely catches my eye. It seems a bit conservative, but we can’t really expect the 5D series to double in resolution every generation. Further even though Nikon will likely make a dramatic leap in resolution for their D800, I don’t think it will surpass 24MP, which would still give Canon their preferred resolution advantage.
On the other hand we’re swayed by talk of dramatic leaps in resolution for the 1Ds Mark IV, given that camera’s image quality bias, and thus its need to compete with the variety of medium format-lite cameras available. It makes a lot of marketing sense for that camera to be in the 30-40MP range, but it would also make a lot of manufacturing sense to use that sensor in more than one camera body (i.e. the Canon EOS 5D Mark III).
发表于 2011-4-22 22:27:48 | 只看该作者
如果是真的话,应该值得期待
发表于 2011-4-23 01:00:52 | 只看该作者
应用了第5代处理器。可惜对焦系统没有改进。
发表于 2011-4-23 09:41:22 | 只看该作者
发表于 2011-4-23 13:28:36 | 只看该作者
Canon EOS 5D Mark III 不知道几钱呢
发表于 2011-4-23 15:05:54 | 只看该作者
原帖由 沙哩 于 2011-4-23 13:28 发表
估计在1.8万左右。
发表于 2011-5-5 11:27:31 | 只看该作者
计划无限期推后了,我不等了,入手MARK2了
发表于 2011-5-5 12:10:24 | 只看该作者
第一次见佳能主动升级。。。。
GMT+8, 2025-7-21 17:19 , Processed in 0.028904 second(s), 20 queries .
