查看: 675|回复: 17
看看这个车模型。注意不是车模,别入错了。
发表于 2007-4-12 20:36:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
如果你想看车模就入错了。呵呵。<IMG SRC="/images/face/121.gif">
<img src="http://www.flatheadv8.org/v8bob/bob3a.jpg">
<img src="http://www.flatheadv8.org/v8bob/bob7a.jpg">
<img src="http://www.flatheadv8.org/v8bob/bob1a.jpg">
<img src="http://www.flatheadv8.org/v8bob/bob4a.jpg">
<img src="http://www.flatheadv8.org/v8bob/bob6a.jpg">
发表于 2007-4-15 00:41:28 | 只看该作者
RE:看看这个车模型。注意不是车模,别入错了。
【(肥仔宇)回复(广州汪汪)的大作】
系5系PS,一看就知道拉!!肯定是真的
发表于 2007-4-13 22:46:53 | 只看该作者
【(广州汪汪)回复(fbcg)的大作】
D鸡肠睇得好鬼辛苦,不如开古啦!
 楼主| 发表于 2007-4-13 17:57:13 | 只看该作者
【(fbcg)回复(fbcg)的大作】
连接在此:
<a href="http://blog.hemmings.com/index.php/2007/04/11/four-links-model-cars-cal-worthington-bristol-crushed-and-vw-sidecar/">http://blog.hemmings.com/index.php/2007/04/11/four-links-model-cars-cal-worthington-bristol-crushed-and-vw-sidecar/</a>
 楼主| 发表于 2007-4-13 17:56:10 | 只看该作者
【(fbcg)回复(肥仔mx)的大作】
呵呵,答案:
As much as I’ve been up to lately, I’ve certainly neglected highlighting the numerous cool articles I’ve come across in a Four-Links.
* First, a group of flathead Ford V-8ers got together to make this awesome 1:1 model car display, though they don’t say which show it appeared at (my guess: a World of Wheels somewhere). This is the kind of innovative thinking that can make a car show fun, not a bunch of cars just sitting around for JimBob and his family to gawk over. Reminds me of Optima’s display at SEMA last year. (via)
UPDATE: Thanks to one of the commenters at Autoblog, we found out that the display took place at the 47th annual Cavalcade of Wheels in South Bend, Indiana, which took place March 17-18.
* The New York Times this week has a profile of California car dealer Cal Worthington (and his dog, Spot). My parents spent a couple years in California in the mid- to late 1970s and said they saw these commercials air all the time, enough so that I knew exactly the Cal Worthington schtick when I was a kid growing up in Ohio.
* What do you do when your local parking officials not only tow your legally parked and legally certified 1972 Bristol 411, but then proceed to crush it? I highly commend Mendoza Stewart on his restraint. (via)
* And finally, sidecars on scooters seem silly. They’re sillier when they’re shaped like a Volkswagen bus.
发表于 2007-4-13 13:09:43 | 只看该作者
【(肥仔mx)回复(fbcg)的大作】
车是真的古董车,其他胶水,小刀什么的,都是道具
发表于 2007-4-13 12:46:18 | 只看该作者
【(开心猫猫)回复(fbcg)的大作】
<IMG SRC="/images/face/129.gif"><IMG SRC="/images/face/129.gif"><IMG SRC="/images/face/177.gif">
发表于 2007-4-13 10:36:38 | 只看该作者
【(cgpeter)回复(fbcg)的大作】
发表于 2007-4-13 09:59:12 | 只看该作者
我觉得系真的, 只不过果D唔系模型, 而行一个艺术展览的场景. 让人好似置身系模型的童话世界中. 鬼老真系咩都谂得出,好有创意
:【 在广州汪汪的大作中提到:】
:【(广州汪汪)回复(嘉小天)的大作】
发表于 2007-4-13 09:21:32 | 只看该作者
【(广州汪汪)回复(嘉小天)的大作】
那么请看看那把工具刀,按照体积则要几个人抬着来用,另外黄色牙膏状(估计是沾合剂)也要几个人抬着来用,还有涂胶水的毛笔也是,我想只不过是用相机重新拍过再处理的,只不过要做成相同分辨率再合成后才比较真实。
另外,如果要做这么大的模型,这很多配件这不会采用整块一起铸造,而是单个配件逐个加工(这么做最后组装出来的效果也是一样的,但加工成本则降低好多),因为这么大一块需要相当大的注塑机,那么这台这么大型的注塑机的成本也相当昂贵了,嗬嗬!反正我是不信。
至于第一张图那桌子和大模型也是可以ps出来的
发表于 2007-4-13 08:56:01 | 只看该作者
【(古怪)回复(广州汪汪)的大作】
留意一下最后一张图,摆小模型的那张台还在大模型中。
发表于 2007-4-13 00:01:03 | 只看该作者
哪是啊?看那两个轮胎就知道不是这样单纯将这个小模型放到另外一个布景了
:【 在广州汪汪的大作中提到:】
:【(广州汪汪)回复(广州汪汪)的大作】
发表于 2007-4-12 23:06:00 | 只看该作者
【(广州汪汪)回复(广州汪汪)的大作】
实际上就是把桌面上的那一堆东西放大后放在另外一个背景,连摆放位置都很接近,不过话说回来,要不是看见桌面上那堆东西以及那把工具小刀和沾合剂的体积还真的会。给骗了
发表于 2007-4-12 23:01:40 | 只看该作者
【(广州汪汪)回复(zoroast)的大作】
应该是ps的,你看那把工具小刀的体积就知道了,另外还有那两瓶胶水。
发表于 2007-4-12 22:35:44 | 只看该作者
<IMG SRC="/images/face/104.gif">
甘大盒, 无个大车房都玩唔起
真定假?  几钱盒,装完莫非要租个车位放<IMG SRC="/images/face/123.gif">
发表于 2007-4-12 22:37:29 | 只看该作者
【(zoroast)回复(fbcg)的大作】
虚则实之,实则虚之!劲啊 !<IMG SRC="/images/face/177.gif">
发表于 2007-4-12 21:53:35 | 只看该作者
【(自动车)回复(fbcg)的大作】
<IMG SRC="/images/face/177.gif"><IMG SRC="/images/face/177.gif"><IMG SRC="/images/face/177.gif"><IMG SRC="/images/face/103.gif"><IMG SRC="/images/face/103.gif"><IMG SRC="/images/face/103.gif"><IMG SRC="/images/face/103.gif"><IMG SRC="/images/face/103.gif">
发表于 2007-4-12 21:15:57 | 只看该作者
【(阿森一族)回复(fbcg)的大作】
有无这么大的车模型啊
GMT+8, 2025-6-7 16:12 , Processed in 0.027520 second(s), 17 queries .
